2.3 ccm with complete built to max, k31 turbo, engine is balanced to 12000 rpm with 7 compression, 3 plate sinter clutch, 6 speed stroged gears, carbon propshaft, bigger brakes...... and so on, dry weight of 1100 kilo. I can it use on the road.
I had last week my first drive with it 7000 rpm and 2,5 bar max at first drive on 100 octan.
I uploaded it vor 5 minutes wait few minutes, i post new videos next week with high boost and high rpm and then with e85, the car has with low setting 750 hp
I have 2,5 bar at 6000 rpm, the turbo is a special one from motair, they build it for me, its nearly identicaly with efr 9180 (the turbine and compressorwheel) but i can use it with 4,5 bar max
