where to get the 3bar map sensor for motronic?
Yeah - I spent a while trying to design a MAP board with the right plug type that could drop directly into a 3-pin PCB connector but I never sourced them. Mark's approach with the little tail plug is neat enough looking and would be easy for most folk to DIY install.Paul Nugent
Map sensor pins on board? V, GND, Vout.?
In another words how to connect those cheap bulk sensors?Attached FilesComment
Plug and Play is worth a lot IMO.
