Thinking I'm going to try and get the trip computer working via a PWM output on the MaxxECU. Rather than try and scope Motronics output I plan to set a linear range against IDC and then tweak it over a few tanks of fuel so the computer tank average matches calculated average. Dmitri or any other Motronic gurus if you are listening, do you happen to know the PWM frequency that Motronic outputs?
Thanks
Thanks
