is there a difference?
  • stevieyid
    • Apr 2005
    • 2251
    Hi i have been looking around now for some porsche 996 calipers. i have found some porsche boxster s calipers are these the same? i was under the impression they were the same. if they are different are they difficult to put on A S2 with 16'' wheels. Are all the carriers and discs the same as if i were doing the 996 caliper conversion? Also what are the part numbers for the front 996 calipers. Thank you for your help
  • 4WheelDrifter
    • Oct 2004
    • 5773
    • Country: Devon
    The 996 Callipers differ from the Boxster S ones in the fact they are a different colour.
    SS
    • Alistair C
      • 693
      same part numbers on both cars - originally designed for the 996.
      Part numbers are in the tables on :
      • stevieyid
        • Apr 2005
        • 2251
        well the boxster s calipers are red i thought? what are the 996 calipers? will the boxster s ones fit with the rs2 calipers carries or machined seat carries?
        • Alistair C
          • 693
          Exactly the same part number on the casting.
          The 'full' part number is the one on the casting suffixed with a 2 digit code to signify the colour.
          996 C2 have black
          996 C4 have silver
          Boxster S have red
          • stevieyid
            • Apr 2005
            • 2251
            so i could still use the boxster red calipers with the a8 discs and rs2 or seat carries. I take it when u lot say about big reds u are talking about the boxster s calipers
            • robo
              • Aug 2004
              • 2086
              big reds=993tt??? is that right??
              sigpic_________
              Rob
              • stevieyid
                • Apr 2005
                • 2251
                not sure mate. just need to no if they will fit on my s2 under the 16'' wheels. i need .
                • rotoryboy
                  • May 2004
                  • 3281
                  Did you read the link Alistair C gave you? If you did read it again
                  Mark
                  Race Clio RS197
                  S2 Coupe ABY (Green) - RIP
                  S2 Coupe ABY (Blue) - Sold
                  • stevieyid
                    • Apr 2005
                    • 2251
                    sorry only skimmed through earlier. after reading through thoroughly i think this statment confirms they will fit.
                    The calipers used hare are 996 items from a non-turbo'd car.
                    They are available on the front of 996 carrera 2 in black,
                    on 996 carrera 4 (four wheel drive carrera) in silver,
                    and also on the 986 boxster 's' in red.
                    would i be correct in thinking this? i need reassurance i dont trust my own judgement . thanks for the help
                    • rotoryboy
                      • May 2004
                      • 3281
                      Yay
                      Mark
                      Race Clio RS197
