Hi i have been looking around now for some porsche 996 calipers. i have found some porsche boxster s calipers are these the same? i was under the impression they were the same. if they are different are they difficult to put on A S2 with 16'' wheels. Are all the carriers and discs the same as if i were doing the 996 caliper conversion? Also what are the part numbers for the front 996 calipers. Thank you for your help
is there a difference?
same part numbers on both cars - originally designed for the 996.
Part numbers are in the tables on :
well the boxster s calipers are red i thought? what are the 996 calipers? will the boxster s ones fit with the rs2 calipers carries or machined seat carries?3'' Longlife Exhaust, Koni Adjustables, H&R Springs, Full RS2 Setup with Mr Nugents RS2 Chips
(just need the RS2 Airbox)Comment
Exactly the same part number on the casting.
The 'full' part number is the one on the casting suffixed with a 2 digit code to signify the colour.
996 C2 have black
996 C4 have silver
Boxster S have redComment
so i could still use the boxster red calipers with the a8 discs and rs2 or seat carries. I take it when u lot say about big reds u are talking about the boxster s calipers3'' Longlife Exhaust, Koni Adjustables, H&R Springs, Full RS2 Setup with Mr Nugents RS2 Chips
sorry only skimmed through earlier. after reading through thoroughly i think this statment confirms they will fit.
The calipers used hare are 996 items from a non-turbo'd car.
They are available on the front of 996 carrera 2 in black,
on 996 carrera 4 (four wheel drive carrera) in silver,
and also on the 986 boxster 's' in red.
would i be correct in thinking this? i need reassurance i dont trust my own judgement
. thanks for the help
