Hot ABS Unit??
    Hot ABS Unit??
    Noticed after a quick blast in the car this afternoon that the ABS Unit was really hot, as in almost too hot to touch, this seems pretty strange to me, never noticed this before and can't think why it should be, unless the pump is running a lot? I'm talking about the unit just behind the main rad with all the brake pipes going through it. Anyone else noticed this getting hot?
    Ta
  • quattronutter
    • Jan 2005
    • 690
    i got a permanently live maf causing that to get hot and drain batt,must be something in the air...
    • dan_b
      • Sep 2003
      • 3670
      I wonder if it could just be heat soak from the hot air exiting the main rad, especially if the fan has been on as the fan blows air back out that way?
