Droning noise from brakes?
    I'm getting a droning from the front brakes (996 monoblocks) which goes as soon as I touch the pedal and comes back again soon after I release it, deffo the fronts as the handbrake doesn't change anything. It comes on after a few miles of driving and is not particularly speed dependant. Any ideas as to what might be causing it? Only thing I can think of to try is to take the pads out and chamfer the edges with a file.
    I've heard it before but forgot about it, but it was really quite loud tonight.
  • Bibby
    • Aug 2004
    • 1043
    Take the pads out and clean the calipers.
    acidtrax
    • Doug_RS2
      • 3847
      Is it only after the brakes get warm? I had that, and popping the pistons out and cleaning them solved all the noise problems.
        Yes, when they get warm. I'll have to strip and clean them. Ta.
          I had this problem with my AP's eventually I got this stick pads that stick onto the back of the pads and that has stopped the vibration
            I've ordered the EBC Reds so I'll do the whole job as one.
            • s2driveruk
              • 12696
              Newsh how much were the reds? also did you have to buy the pad backing plates, if so where did you source them from (the ones which stick to the back of the pads and then locate in each piston). I'm about to mount my 996's this weekend hopefully on 323x30's...
              1992 3b S2 Coupe
              • 4WheelDrifter
                • Oct 2004
                • 5773
                • Country: Devon
                You mean the 'Brake pad backing plate thingies'?
                Click here and the P/N is in post #10
                SS
                  might be, they are different on my pads though
                  • s2driveruk
                    • 12696
                    cheers drifter....i have them supplied with the calipers but i think they have seen better days. While i was searching came across some round shims which are listed for the boxster s/996 wonder what the difference is....
                    See here: http://www.porscheshop.co.uk/acatalo...omponents.html
                    so do i need these and the backing plate or just one or errrr umm?
                    David
                    1992 3b S2 Coupe
                      Reds were about 90 quid from ebc brakes direct. I havent bought new backing plates this time, didn't think I'd need to.. Last set I think I got from Design 911.
                      You can see the shims in this pic, thats all I used the black strip with 2 round bits on.
