Braided brake lines
  • daxyz
    • Apr 2005
    • 80
    Dan, Please let me know how you get on with this one. I have Porsche monoblocks on and RS2 hardlines - I am looking to replace the remaining flexi hoses with braided lines but VAGParts drew a blank and suggested Tekkno435 as a possible source (still waiting to hear from him re price and availability).
    I will send pm and see if there's any progress.
    Derek.
    '93 ABY by MRC.
    • s2driveruk
      • 12696
      Dan, here you go, that link you posted didnt work but heres the details from vagparts:
      Pair of front RS2 caliper brake lines
      Pair of the RS2 front brake copper pipes to use with the big reds.
      Order number: 8A069872*
      Our price: 13.75 GBP
      1992 3b S2 Coupe
      • dan_b
        • Sep 2003
        • 3670
        Yes they're the ones - I was just a bit confused as the main title description says for RS2, but then the detail description says for Big Reds - I figured that because the Big Reds run on a bigger diameter disc that the caliper lies further "out" so the connection to the hose would be in a different place, meaning this solid pipe wouldn't work for both?
        • s2driveruk
          • 12696
          yeah understand, though even on the 996 calipers which have a centred hole for the hardline compared to the RS2's offset (lower than centre) you can manipulate these quite easily by just making a couple of small kinks in the pipe.
          Pedal feel is soo much better with a rigid pipe, I'll wait a few months then make the top flexi's braided so that should improve them again.
          1992 3b S2 Coupe
          • dan_b
            • Sep 2003
            • 3670
            #20
            I've been meaning to do this for a long time, as you say it does improve the pedal feel rather a lot. Another order coming the way of VAGParts it would seem!
            • Martynf
              • 1885
              Cheers Dan!!!
              We will also have a full set of ALL the stainless steel lines available REAL soon too! :-) the RS2 ones are done, and soon we'll have Coupe kits, Avant kits and S2 Equipped with big red kits, Coupe or Avant!!
              I've had hoses made to my specs, so they'll all be stainless steel and clear coated brake lines, with stainless steel not zinc ends and TUV approved too :-)
              If anyone wants a full set of hoses, or just the fronts, or just the rears etc... please e-mail me as I'll be getting the hose order placed very soon. Mail me on martyn@partsforaudi.info
              Martyn
              www.vagparts.com
                #22
                TUV approved flexi hoses - Sweet !
                Got any pictures ?
                They just might get added to an imminent order for you Mr. F !!!
                Paul
                • HPmuirt
                  S2Forum April Fool
                  • Apr 2005
                  • 3014
                  #23
                  Originally posted by Martynf
                  We will also have a full set of ALL the stainless steel lines available REAL soon too! :-) the RS2 ones are done, and soon we'll have Coupe kits, Avant kits, Rs2 kits and S2 Equipped with big red kits Coupe or Avant!!
                  Having recently done the monoblock upgrade, including using your lovely RS2 hardlines, the one thing remaining for me is the flexi lines, so I would certainly be interested.
                  Can you give us some feeling on prices please?
                  Cheers n
                  Si
                  Gotta another one for you to add to your undoubtedly long list of future parts to be added.......Porsche Monoblock front pad shims....As I bought the RS2 ones, thinking they would fit
                  Subtle mods here and there
                  2011 A5 3.0 TDi - Lava Grey
