Hello everyone,
I was at the garage the other day and was discussing the issue with the awful RS2 handbrake.My RS2 has no handbrake at all now,and i only use the gear to park.
I was also told by my mechanic that it is useless to try and tighten everything back cause it will disengage again after a couple of tries...so...
I thought of something like the picture above.
I have noticed that many cars have extra small calipers in the rear wheels for the handbrake.The cables are connected to them and the handbrake is executed by the pads on the extra calipers which usually sit on the opposite side of the rear brake caliper.
Is something like that doable to the RS2?Can the cables be disconnected from the rear handbrake and reconnected to the new extra calipers?
has anyone ever tried something like that?
thanks
Vasilis
Cleaned everything, used new cables and adjusted shoes: everything
, (although in snow it can be fun)what i mean is, say you pull up at home, put on your handbrake which:
