Hi all,
Anyone got any experience or ideas on what brackets are made to fit my 996 calipers with 323mm X 30mm discs to my S6 (Currently HP2 setup). I understand the calipers were originaly designed for 28mm discs and the pins will need grinding a bit. I originaly asked MBT if they had brackets that would work and they said yer no prob use the MBT141's then as soon as I mention I'm using 323mm discs they say no won't fit? I'm getting a bit sick as this is the last piece of the jigsaw and the calipers have been sat by my PC for months now
If after all this their is'nt any brackets available, I will look at getting some manufactured, then the question is has anyone got any advice on the material I should use?
Cheers in advance for your help
Ben
Ben
