Brakes for S2
  • cadyS2
    • Nov 2005
    • 7
    • Country: Slovenia
    Brakes for S2
    Hello, brand new to this forum.
    I started modifying my S2 1991. Need advice on brakes. Did anyone used something other than 996 or 993 calipers?
    Thinking of using Audi stuff. Maybe S8 or
    Please help!
    C.
  • kwlw
    • Sep 2004
    • 1025
    • Country: Lithuania
    C.
    Putting 996 front calipers, RS2 brackets and A8 disc is going on tested, effective (in terms of cost, and performance) way.
    If you want to invent bike (like I do), then it's ok to put something else. S8 stuff is very similar to 993 calipers. I collect brake porn with photos, dimensions. So if something, I can try to search for some info. S8 calipers should bolt to RS2 brackets, but I have no idea what offset will be required for disc. And note - after much work it can be, that braking performance will be significantly worse than 996 route.
    One more wise way is to go for alcons, willwoods or another racing pedigree stuff without alchemy with brackets, machining brake pats, and co.
    Sau
    • Jeffer
      • 2057
      Perform a search on the forum aswell. There are loads of threads on brake upgrades.
      good luck!
      RS2 Black - stock 315 HP
      RS2 RS blau - stock 315 HP
      Sport Quattro - 1005 HP
      High Octane website
      • Fat Audi 80
        • 10547
        [shout]BRY![/shout]
        The Perfectionist
        • dan_b
          • Sep 2003
          • 3670
          Spend a good few hours searching through the brake upgrade threads, there is a huge amount of innovation in various brake upgrade routes here, ranging from bolt-ons from existing stock (as Sau has outlined above), to complete custom kit with 6pot APs on 380mm discs.
          First thing to establish is "what's your budget"? Using off the shelf stuff, you can squeeze it all in for about £500 with careful purchasing, and rising for more ambitious kit.
          Glad you're taking the brake upgrade route though - are you planning any other upgrades?
          • cadyS2
            • Nov 2005
            • 7
            • Country: Slovenia
            Sau
            Like it seams,
            I will go the same road as most folks.
            Don’t have much time. My car MUST be running by the end of April!
            Thx C.
            • cadyS2
              • Nov 2005
              • 7
              • Country: Slovenia
              My budget?
              Well started with 6.000 EUR, raised to 12.000, and now at the mid still going up.
              Other upgrades – to build a car that goes low 11 s in 402 meters (500 hp++), and stops by him selfs.
              C.
              • Ice
                • Jan 2005
                • 24
                What about this setup:
                A8 discs
                Seat carriers (modified)
                Wilwood Billet SL4R calipers
                These calipers are dust-sealed, so they should be good for street. They are light-weight and price is definitely friendly.
                I'm seriously thinking of going this way as the price-difference compared to porche brakes is quite big. Someone smart should only tell me the exact caliper model (part-number) to go with...
                Audi B4 TQ equipped with AAN and other nice parts
                • Ice
                  • Jan 2005
                  • 24
                  Can anyone comment the last set-up listed...?
                  • BRY
                    • 3755
                    You can't use the SEAT brackets as the mounting holes on those calipers are not at 130mm.
                    • Ice
                      • Jan 2005
                      • 24
                      ok, thats a start bry So its custom brackets then... But what about the general idea of using wilwood calipers that are dust sealed? How much are they dust sealed, good enough for everyday road use in the land that has snow, ice and loads of salt (read: potential corrosion)? Also what bore size to use?
                      • Audi500HP
                        • Apr 2004
                        • 85
                        • Country: Chile
                        Who is the guy who try to plug Cayenne brakes? I know that everything its possible if you want, but that its too much.....
                        Can it done?
                        Lets do a pot of money and a competition for the Biggest Brakes possible!
                        Audi S2 94 6 speed ABY-ADU 330hp, Lancia delta EVO2 mint
                        Dr.Ferdinand
                        • dan_b
                          • Sep 2003
                          • 3670
                          I don't know anything about Wilwood Calipers, don't know if anyone on the forum is using them on the s2? I know people tinkered with Hi-Spec calipers but had problems?
                          Someone here is fitting Cayenne calipers, and someone else has just fitted 8-pot Brembos from a Merc, others have done AP 6-pots. If money is not really an obstacle, there are plenty of imaginative custom-routes you can go down.
