S4 Brake upgrade
  • S4 Miss
    • Nov 2005
    • 172
    S4 Brake upgrade
    I want to upgrade the brakes on my 1992 S4 avant...any pimping yet vaguely affordable suggestions and sources for parts?
    All the Gear... No Idea
  • kwlw
    • Sep 2004
    • 1025
    • Country: Lithuania
    UFO at the front ?
    Sau
      you could try the porsche 996 type upgrade, costs ~£500
      check the brake section for more details
      • Corey
        Banned
        • Sep 2003
        • 2793
        I would love to help you achieve a Porsche monoblock conversion for your S4, if you would like any reccommendations please contact, Dave Orrell (quattroboy) or Jaap Wissman (Jaap) whom both post here.
        If you look in the thread
        You can see some details about a conversion I did on my S6
        Corey
        01636 822288
        • Rusty
          • 18953
          Porsche is a good value for money solution at around the £500-£600 mark. Bry may be able to help as he's done a few S2s, me included.
          • S4 Miss
            • Nov 2005
            • 172
            Corey I am feelin' the love for your conversion! Check your quattro finish out!!!
            I think the S4 might be getting some of those babies
            Oh, and yes, the fronts are UFO's at the mo...
            • kwlw
              • Sep 2004
              • 1025
              Then you will need different caliper carriers than Corey has build and used.
              Sau
              • S4 Miss
                • Nov 2005
                • 172
                It has been suggested to my good self that the only disc that will fit the UFO hub with minimum machining is actually a Merc SL500 AMG front disc...comments/opinions please boys
                These uS4/100 UFO's/floating calipers sound like a nightmare...
                • merlin's S4
                  • Jan 2005
                  • 1539
                  I need to get rid of my ufos too. I've been looking for a fairly straightforward upgrade route for some time but haven't had much luck! There's some upgrades available in the US but none are particularly cheap, especially when you add the cost of importing the kit! I've been planning on just getting hold of some big discs and calipers and then getting a custom bracket made up to mount the caliper but I haven't got round to doing anything just yet. If anyone on here can help in any way, I too would be glad to hear your ideas!!
                  • merlin's S4
                    • Jan 2005
                    • 1539
                    I think that even this disc needs the wheel stud holes and disc centre hole enlarging slightly!!
                    • JPL
                      • Oct 2004
                      • 149
                      Yep they do, I've had mine machined already and they fit fine.
                      Disc centre and bolt holes need taken out by 1mm each, plus a few thou a clearance fit.
                      Graeme.
                      94 UrS4 Avant, slowly modding as we go. Now gone replaced with:
                      2001 S6 Avant, V8 works for me!
                      • Corey
                        Banned
                        • Sep 2003
                        • 2793
                        Used to have an S4 that had mono's also.
                        Corey
                        01636 822288
                        • S4 Miss
                          • Nov 2005
                          • 172
                          you've got mail mister..
                          jessica
                          • pastures16
                            • 2058
                            yet another female warrior welcome to the darkside
                            94 s2 avant
                            aoc member 1116
                            • S4 Miss
                              • Nov 2005
                              • 172
                              I was ruined by an RS2 related incident...never looked back...:mischeif:
