i have a of geting some calipers calipers from local scrap yard he says there of 911 and 996 GT3 turbo but before i get them can some one tell me if there right a the job
part numbers 996351429
996351430 last time i bought some calipers they were wrong and lost on them
he says there off a GT3 and they are fronts but the last bloke said they were of the fronts and when they came they were wrong so i need to check the part numbers before i buy them or would these be better P/N 996.352.425.02
996.352.426.02
996.352.426.02
I just bought a pair of 996 calipers myself, (same number as you) and i were told they are the rear calipers on a 996 porsche.
996.351.426.02 is front calippers
996.352.426.02 is rear
But i wonder, are those the same size as the front ones? and just the caliperpistons which is smaller on the rear, or am i totally wrong?
i wonder if they can fit the ordinary rs2 calipercarrier ?!
so ive established that if all the info that the bloke give is right they are fronts so will these bolt to the rs2 carrier and what size of disc will go with this caliper
Custom brackets are the only option to fit these to Audi's, I am fitting a pair of these to an RS2 and am using Porsche 2 piece discs. So the same disc could be used but with a custom bell to adapt it to fit the S2.
Hi i have gone and bought some 996 351 429 / 996 351 430 calipers thinking that they could fit using the normal parts untill i seen this thread. Can a off the shelf disk be used and what price would i be looking at to get a hold of brackets to make it fit.
Thanks.
1994 Indigo Blue S2 coupe
1994 80 Avant 1.9 TDI
2005 Yamaha Fazer 1000
1953 AJS Model 18S
