caliper part number
  • wigan!
    • 21
    caliper part number
    i have a of geting some calipers calipers from local scrap yard he says there of 911 and 996 GT3 turbo but before i get them can some one tell me if there right a the job
    part numbers 996351429
    996351430 last time i bought some calipers they were wrong and lost on them
  • Corey
    Banned
    • Sep 2003
    • 2793
    4 pot GT3 fronts
    Corey
    01636 822288
    • wigan!
      • 21
      he says there off a GT3 and they are fronts but the last bloke said they were of the fronts and when they came they were wrong so i need to check the part numbers before i buy them or would these be better P/N 996.352.425.02
      996.352.426.02
      • AndersS2
        • 1364
        • Home: Norway
        996.352.426.02
        I just bought a pair of 996 calipers myself, (same number as you) and i were told they are the rear calipers on a 996 porsche.
        996.351.426.02 is front calippers
        996.352.426.02 is rear
        But i wonder, are those the same size as the front ones? and just the caliperpistons which is smaller on the rear, or am i totally wrong?
        i wonder if they can fit the ordinary rs2 calipercarrier ?!
        Anders - S2 Avant Clubsport - 8pots or die!
        • wigan!
          • 21
          the part numbers ive got are the fronts so will they do the job
          P/N 996.351.429
          P/N 996.351.430
          • Alistair C
            • 693
            See HERE for caliper part number info.
            • wigan!
              • 21
              so ive established that if all the info that the bloke give is right they are fronts so will these bolt to the rs2 carrier and what size of disc will go with this caliper
              • twoqu
                • Sep 2003
                • 3103
                Hi!
                No! The bolts spacing is wider on the GT3/Turbo calipers. Think its 142mm rather than the more common 130mm on the other 996/Boxter S calipers.
                • Corey
                  Banned
                  • Sep 2003
                  • 2793
                  Custom brackets are the only option to fit these to Audi's, I am fitting a pair of these to an RS2 and am using Porsche 2 piece discs. So the same disc could be used but with a custom bell to adapt it to fit the S2.
                  Corey
                  01636 822288
                  • wigan!
                    • 21
                    so are these calipers better than the standard rs2 calipers
                    • Corey
                      Banned
                      • Sep 2003
                      • 2793
                      You've got a PM replied to
                      Corey
                      01636 822288
                      • YELL MAN
                        • Dec 2005
                        • 535
                        • Country: Shetland Islands
                        Hi i have gone and bought some 996 351 429 / 996 351 430 calipers thinking that they could fit using the normal parts untill i seen this thread. Can a off the shelf disk be used and what price would i be looking at to get a hold of brackets to make it fit.
                        Thanks.
                        1994 Indigo Blue S2 coupe
                        1994 80 Avant 1.9 TDI
                        2005 Yamaha Fazer 1000
                        1953 AJS Model 18S
