Faulty "BOMB" Hydraulic pressure accumulator?? Advice please guys!!
  • s2dude
    • Nov 2005
    • 1631
    ok. I;m running through a list of jobs to put the 3b I bought into to good running order...
    It has a few problems relating to the brakes though and Im sure after searching on here and elsewhere its the BOMB hydraulic pressure accumulator ....
    Points//
    -pedal feels like it lacks assistance a lot of the time while driving
    - Ive done the BOMB test and it failed dismally!!! The pedal went "hard" after about 3 presses when the engine had been turned off
    - Brakes feel weak anyway but I've heard this is inherent with stock 3b brakes anyway!!
    ok. I read the article on 20v.org and Im going to do the recommended test for the bomb but I'm assuming it's knackered ssing as the article says after 7 years they are normally dead anyway
    Before I try and source a sensibly priced bomb (Im not paying £250 dealer price!) has nayone done this job before and how far out is that guide on 20v.org seeing as its not an S2 and also it's a LHD car meaning possible different location etc
    Ive been told the bomb is in an awkard place to get to and that its a bitch of a job? but I see a poster who said he did his in half an hour??
    Can anyone enlighten me on a proper time for the job? and is it easy or a pain the RS?
    // Also, my ABS light keeps coming on at random times....I havent been able to test the ABS yet (saturday) but is there any common things I should look for to try and ID the problem?? ie// faulty ABS sensoe or whatever?
    Thanks in advance guys
  • 4WheelDrifter
    • Oct 2004
    • 5773
    • Country: Devon
    The bomb isn't hard to get to.
    Just stick your head under your engine and look towards your nearside wheel.
    SS
    • s2dude
      • Nov 2005
      • 1631
      hehe!!!
      Thanks for that 4wheel drifter!!
      Great photo action.....is it just as easy to remove and swap it then?? and am I ok to follow the 20v.org guide do you think?
      • 90quattrocoupe
        • Nov 2003
        • 771
        There is a guy on Audifans who rebuilds the bombs. Does good job I understand and does it for about 100 USD. I don't remember his email, but you can join Scars on audifans mailing list, and ask who it is.
        Greg W.
        • 4WheelDrifter
          • Oct 2004
          • 5773
          • Country: Devon
          I should think you'll be fine following the guide on 20v.org. Just make sure you depressurise the bomb before you attempt to remove it. Pump that pedal!
          Greg, is the guy you're talking about in the US? I'm not sure if there are any issues with shipping a 'bomb'.
          SS
          • 90quattrocoupe
            • Nov 2003
            • 771
            Hi,
            Guy is in the States. I hadn't thought about the shipping aspect. Maybe just don't write on the package "car bomb". Maybe just, brake pressure accumulater.
            Actually the guy is on the Quattro list on Audifans.
            His name is, Dave Kase, his email should be "davekase@pdqlocks.com"
            Greg W.
            • s2dude
              • Nov 2005
              • 1631
              Thanks guys. appreciated
              May not be the best time to ship a "bomb" in to the uk
              • nigelm
                • 150
                Bomb Source
                You could try a Febi brand bomb.
                Look under pressure accumulator - I think part no 14176 (best make sure though)
                May be cheaper than other options.
                nigelm
                • philS2
                  • 356
                  quote from previous post "Give The 7 Star Garage a bell, on: 01487 831 239
                  They mainly do Citroens, but I know that they did recharge Audi bombs about a year or so agao when I wanted my one done."
                  worth a try.
                  • s2dude
                    • Nov 2005
                    • 1631
                    worth a try.
                    Mm. Interesting. Thanks very much Phil.
                    I will give them a call mate. //just read that other thread.
                    A refill sounds very promising!!!
                    • s2dude
                      • Nov 2005
                      • 1631
                      Great//
                      Phoned the garage above.
                      Now called :
                      Pleiades
                      Greenend house
                      Scotley Way
                      Sawtry
                      Cambridgeshire
                      PE28 5XF
                      (thats where you ship the bomb to anyhow!)
                      Same price (about £75) + postage
                      They said the bomb can normally be repaired but sometimes they are shot.....the guy said if they are left till they are totally depressurised then a certain part inside (pistonthingy?) punctures a seal rendering them scrappers.
                      The motto he said was don't wait until the unit totally fails and dont keep driving with it or it may be scrap.
                      I'm posting mine there monday anyway so will find out Tuesday ish.
                      Just to check....I read another post where a poster said he kept pressing the brake pedal till it went totally soft as a test for the bomb?? and it took 48 presses or something??
                      I thought it was how long it took to go "hard"
                      Can someone clarify please.
                      TIA
