any one got a pic of a porsche monoblock and 314mm disc under a 16" Avus for me to look at?
314mm dics under an Avus 16"
Tags: None
with rs2 brackets:
after one week there were score lines on the calipers where the wheels had made contact. At best there was 1.5mm clearance.Attached Files -
and......
plenty more pics if you search the archives.Attached FilesComment
ta for the pics looks like they go on fine. is this 314 set up vastly better than the standard one?Comment
is there a part number for the 314 discs that you have to hane or are there several fit ments according to the monoblock caliper chosen. the ones i have in mind are blacl monoblocks if that means anything. whilst i am on what is the size of a std S2 disk and are the std S2 calipers single or twin pots?
are the black porsche monoblocks 4 pots?Comment
All black monblocks are not the same, the part number's are the guiding factors. If you are going to use the RS2 bracket on the 314 disc you will need to machine it soo that you can obtain the correct pad contact on the disc.Originally posted by lee davenportis there a part number for the 314 discs that you have to hane or are there several fit ments according to the monoblock caliper chosen. the ones i have in mind are blacl monoblocks if that means anything. whilst i am on what is the size of a std S2 disk and are the std S2 calipers single or twin pots?
are the black porsche monoblocks 4 pots?Corey
01636 822288Comment
aah - but now those disks look tiny under the blingtastic 18s.Originally posted by Jamo*Cough* small wheels no longer apply :mischeif:
When you want to offload those 'horrendously and irrepairably butchered' calipers to replace with some which'd fit a more appropriate 340+mm disk - let me know....Comment
Originally posted by Alistair Caah - but now those disks look tiny under the blingtastic 18s.
Thats what i was planning to do as well especially if Bry had his way
my plan was to use a Seat bracket suitable to space out the caliper fir use with a 314mm A8 disc. to do this successfully does anyone know the monoblock part number so i do not buy the wrong calipers.
ta
leeComment
Past: S2 ABY coupe RS2 spec with lots of mods, S4 B5 saloon, RS6 C5 saloon, S8 D2 FL, RS4 B7 saloon, S4 B6 avant
Present: S4 B8 avant, MRC Stage 2Comment
If I recall correctly the rear caliper on the 996 GT3 is the same as the front caliper on the Boxster S (986). At least according to the casting #s on the calipers:mischeif: Also, the caliper piston sizes are the same for both the front Boxster S and the rear GT3. The Boxster S comes with larger calipers both front and rear when compared with a standard Boxster."Nulla tenaci invia est via"Comment
Casting is the same but is machined differently and the pistons are smaller on the GT3 rear than the S.If I recall correctly the rear caliper on the 996 GT3 is the same as the front caliper on the Boxster S (986). At least according to the casting #s on the calipers:mischeif: Also, the caliper piston sizes are the same for both the front Boxster S and the rear GT3. The Boxster S comes with larger calipers both front and rear when compared with a standard Boxster.
Boxster S front calipers are the same as the 996 Carrera, 996.351.425 and 426Corey
01636 822288Comment
