996 refurbed
  • Crawford_S2
    • 1555
    996 refurbed
    Well got em done and very pleased with the results
    What you think? Recognise them Bry??
    Did the Seat brackets too, not sure what to coat them with though.
    Got to get em all strapped on now, wheres that brolly
    Ragusa Coupe gone!
  • MidnightBlueS2
    • Jul 2005
    • 1653
    • Home: United States Current: Belgium
    Good job !
    But you'll see that they brake even better then they look !
    Midnight Blue S2 - SOLD - 1993 S2 Avant
    • Jas11n
      • 5067
      Very nice.
      Did the Seat brackets not have a gold-ish coating on them? All the ones I've seen have come colour passivated (sic?)
      Jas.
      2001 Avus Silver B5 RS4.
      1995 S2 Coupe - sold (sniff)
      • Crawford_S2
        • 1555
        Originally posted by Jas11n
        Very nice.
        Jas.
        The Seat brackets did have a coating but i have had to machine them and not sure if the 'raw' faces will corode or not. Dont want to lather two pack on them either as any thickness of paint may effect fit.
        Ragusa Coupe gone!
        • Jas11n
          • 5067
          I coating of a good etch primer should be enough on the bare machined faces, though they aren't going to be rusting through quickly
          Damned hard stuff those Seat brackets are made of, I burnt out one cutting tip (had to use a ceraminc tipped one instead) whilst machining Si's (HPmuirt's) for him.
          Mine are an exact copy of the Seat, but made of EN8 tooled steel and I just sprayed them with a couple of coats of etch primer. Still look good there now even after 12months of use.
          • Crawford_S2
            • 1555
            Thought about etch but the tart in me was screaming out for some kind of electro-plating, will probably end up with etch though
            Ragusa Coupe gone!
            • A80Avant
              • Sep 2005
              • 10873
              • Country: Greece
              very nice job by the way!
              i want to repaint my calipers as well.Im getting some paint delivered from ebay.co.uk guy.and intent to do it by brush not spray.Am i going the right way here?
              thanks
              Vasilis
              • Crawford_S2
                • 1555
                thanks
                Vasilis
                Up to you bro but the money i spent on my calipers i thought it was worth spraying them. Besides my mate did em buckshe!!! (Free, my favourite price, nice one Wayne )
                Ragusa Coupe gone!
                • A80Avant
                  • Sep 2005
                  • 10873
                  • Country: Greece
                  well,what i meant to ask is that withyour experience,is it a better job done with a spray or a brush?
                  cheers
                  Vasilis
                  • Corey
                    Banned
                    • Sep 2003
                    • 2793
                    The original SEAT brackets have a zinc passivate finish, this is a sacrifical surface treatment, this is designed to corrode and form a protective barrier and hence prevent the underlying metal from corroding. If you have removed this finish you risk it rusting.
                    I can get them replated for you, if you want???
                    Corey
                    01636 822288
                    • BRY
                      • 3755
                      No, I don't recognise them.
                      They do come up well, don't they?
                      Nice job, does your mate Wayne want some others to paint?
                      • Crawford_S2
                        • 1555
                        Thanks for the info and the offer, will sort it locally though cos they need to be on the car ASAP!!!
                        Ragusa Coupe gone!
                        • Crawford_S2
                          • 1555
                          He is a top painter, i did the prep, just a quick scotchbrite off and a degrease then he threw on a light coat of etch and two or three of brembo red, job in the town! Expect if you had a batch you wanted doing he would happily oblige.
                          Want to buy em back, i have it on good authority that they are worth 350 all day long now Joking wont sell em now, thanks again for your help sourcing bits
                          Ragusa Coupe gone!
                          • Crawford_S2
                            • 1555
                            cheers
                            Vasilis
                            Spraying is much better bro, the finish is factory. Brushing is very difficult to get to look good. Just my opinion.
                            Ragusa Coupe gone!
                            • 4WheelDrifter
                              • Oct 2004
                              • 5773
                              • Country: Devon
                              cheers
                              Vasilis
                              Brushing is no problem. I used Hammerite on mine and got a very smooth finish. The only thing is, I would advise letting the paint cure for about 2 months before you handle them.
                              Here's one picture I have to hand:
                              HTH
                              SS
