Brushing is no problem. I used Hammerite on mine and got a very smooth finish. The only thing is, I would advise letting the paint cure for about 2 months before you handle them.
HTH
That is the problem with hammerite, it does take ages to cure. Thats why i went the two pack route, its baked then you can handle it straight away
Both are fine done well but both also have their problems.
Nice job with a brush BTW
Reason: Spelling like a gimp!
Ragusa Coupe gone!
Bolted the new bits on today and it took no time at all Less than an hour a side with tea and **** scratching. Bleed em up and it was like someone had put a block of wood under the pedal, it is there and rock solid, absofeckinlotely marvelous
Before
After
Couple whilst i fooked about fitting them
Once again big thanks to Bry for his help on this, the whole lot went on like it was ment to be there, no hassle or fit issues, highly recommend anyone wanting an upgrade to give him a pm
Thanks to the lads at VAG Parts too, you boys definately know your stuff
Even fake calipers
Ragusa Coupe gone!
Before anyone says anything, yes i did put in the pins and anti rattle gubbins, just hadn't at that point. One thing, did have to 'tweek' the fit on the brake pipes but they could have been sat on at the post office
Ragusa Coupe gone!
Just told my insurance company about the new stoppers, they reckon they want 11 quid Its no amount but why put it up at all
Suppose i have just increased my chances of getting hit up the catflap but have at the same time reduced the risk of killing wildlife
Wouldn't mind but bet they wouldn't put the uprated brakes on a replacement if some twit wrote off this one
Ragusa Coupe gone!
Bought me some black caliper paint from the bay,and painted them by hand and brush.The original red paint was heavily cracked and damaged in many places,but i had already spray painted the calipers black(mat) using a heat resistant paint.Now i wanted something more bling looking,and also original porsche looking so here are the results.This was done quite fast i must say,during an afternoon.Then the car rested for 3 days,then i placed the decals.
Ragusa Coupe gone!
oh and sorry for the highjack groofosp!
by the way,i could have done a much better job by taking them off and scraping them down to bits with sandpaper,but i only did that a little bit so as not to scratch them around.Besides from afar you can't tell the little details that needed further attention!
thanks mate!
cheers
Vasilis
hey. i have some RS2 front calibre for my S2, these i will use with A8 discs.214x30mm.
But that SEAT adapter you all talk about, what is that, ?? eny picture ???
This is the bracket from seat that i had modified at the machine shop (PM Bry for exact details) The p/n at seat is 6KL 615 421
I used the 323x30 disc though not sure if they work for the smaller one or not
Ragusa Coupe gone!
Okay, i will buy these 6KL 615 421 from my local SEAT dealer.
i will use the 314x30 so i can have my 16" winter tyre.
but shall i do somthing with the SEAT adaptor to make them fit. ???
any picture,??? or will I automaticly se it, when i try to mount them on the car.???
just a quick one will the porka calipers fit on mi 90,i know i will have to change the wheels but discs are 5 stud i need 4 so which ones would fit.john
1990 100 2.2 10vqt 82k miles(now dead)
1990 90 2.3 20v 166k miles
1988 90 2.0 10v 181k miles
oh and a polo for work.
These will need modifying but can't tell you how cos you are running different discs and calipers to me bro, search and you shall find!!
Ragusa Coupe gone!
