ok guys.
WELL annoyed about this
Bought a brand new bomb (much waiting as wrong one sent first)...fitted it having drained all fluid...cleaned everything up and used new mounting rubbers and so on (bit of a sod of a job)
I topped up with the correct grreen audi hydraulic fluid (New), and started her up ....after 30 seconds or so I could hear a strange sound form the front end of the car. Like a whirring grinding sound.
So I turned it off. Back on a minute later and all was quiet.......thought I would bleed the system Lock to Lock.......horrible noise again....as I get near to the end of each steering turn it squeals and sounds really upset
Left car running > identified noise as coming from power steering pump area and also there was fluid seeping fairly heavily out of that big CROSS in the top of the pump!!!!
So what now?? The Exclamation light is still as on as I dont think the pump had the guts to charge the hydraulic pressure accumulator back up???
Is my Power steering pump toast??? (hope not
will mean more money into this car!)
or do you think it could just be the seal under the cross head bolt? could this cause this whirring nasty noise though?
Is there a bearing or something that can fail in the pump?
Also...worst case scenario ...how much is the pump??
All ideas and suggestions welcomed please
will mean more money into this car!)or do you think it could just be the seal under the cross head bolt? could this cause this whirring nasty noise though?
although when I do the bomb test it has over 40 pumps till the pedal goes hard and braking is noticeably better (apart form a disk is now binding on the pads due to highspots//another story!//)
(Im selling it!)
