ok guys.
So I got to stripping down the brakes to fit new disks and pads a couple of days ago...
Was expecting an 2 hour job in total including cleaning up the calipers and slides etc and getting the car running again...
But No.....it couldnt be that simple!!!
Some dufus who owned the car previously (or a mechanic who worked on it) had rounded the 17mm bolts that hold the Front Brake Caliper Carriers on......
So my nearly new 17mm Britool socket just turned on it when I gave it any effort...
not good and to cut a long story short I managed to presuade one bolt from either side to come out..the top ones as it happens.
I looked at it a few days ago with Bry and Andyp and the consensus was to cut the bolt heads off as precisely as possible so I could waggle the disc and persuade the carrier off that way. Then take the disc off and work out how the hell I would get the remaing 80% of a very highly torqued bolt out of the mounting braket that the lower bolts fasten into....
pictures below highlight the work done and problemn Im now faced with
The Carrier WOULD not pull back away form the disc enough to allow me to slide it out of the bolt hole (the remaing half bolt anyway)
and the disc wont come off either ....leaving me a big problemo....!!!
Im looking for if anyones ever had rouned caliper carrier bolts before and what the heck they did ....also ideas on the best way to move forward......
see more text in next post
Starting
Tricky access (ended up having to rotate the guard..dodgy..)
After LOTS of cutting and grinding (cuttting is a major PITA because the bolt is skirted you cannot get all the way to the back of the bolt head meaning more grinding being super careful not to grind the Casting that it bolts through!!
Getting there
The problem now is getting the bolt cut back flush to the casting so it can slide through freely ...without grinding up the casting!!
Starting
Getting there
