Tricky Technical Problem!!Removing Seized Caliper Carrier Bolts. Ideas Please!!!
  • s2dude
    • Nov 2005
    • 1631
    more
    • s2dude
      • Nov 2005
      • 1631
      and more
      • s2dude
        • Nov 2005
        • 1631
        • s2dude
          • Nov 2005
          • 1631
          and yet more
          • s2dude
            • Nov 2005
            • 1631
            Mmm. dont try this at home folks
            • s2dude
              • Nov 2005
              • 1631
              Still got the caliper carrier in tact
              • s2dude
                • Nov 2005
                • 1631
                and finally...you will come out you little **************
                • s2dude
                  • Nov 2005
                  • 1631
                  and out she came no problemo....
                  Though I would NEVER recommend trying this route unlesas all other avenues are gone!!!
                  Got looking at the other side with my Dad whos a bit of a DIY pro type and we ended up re grinding new flats on to the bolt and got it down to a trim 16mm with straight edges
                  Came off with a bit of persuasion from a breaker bar and by FAR the best route I could have taken.....The bolt was like new (only smaller and a few shiny patches!!!) and was totally rock solid in the socket luckily so this is without doubt the best way to do it if you still have an intact bolt head.
                  Just have to be very be methodical and precise so you take the right amount of each flat so you still end up with a symmetrical bolt......
                  I only wish I had done it on the other side.......
                  Grinding those disks was a total mare with a 4 1/2 " grinder and a 9" would be too big....very very tricky not to take chunks out of the hub or brake pipe so a lot of care was needed.
                  Also....the bolt would not pull through even with the head ground flush as there is a skirt on the bolt inside the carrier...had to grind a small amount of the flat caliper carrier face to get the bolt free....as can be seen in the solo pic of it above...though it's still totally flat and wont affect anything as its only about 1mm of material gone.
                  @ 5 hours ++ labour first side.... 45 minutes second side
                  • iain1067
                    • 984
                    well done, reminds me of having a locking wheel bolt not come out, ended up going to a local eng firm who turned a bush to fit the bolt hole in the wheel with a hole down the centre so we could drill out the bolt head, worked a treat i still have the bush to this day just in case.
                    Iain
                    • s2driveruk
                      • 12696
                      well done, glad you're sorted out!!! Personally i'd clean everything up before re-assembly. I used hammerite high temp paint on my carriers and calipers and it lasted well for a good couple of years and hopefully you'll have less probs downstream
                      1992 3b S2 Coupe
                      • s2dude
                        • Nov 2005
                        • 1631
                        Thanks guys
                        Heres the little beauty of a bolt now
                        • s2dude
                          • Nov 2005
                          • 1631
                          and this
                          • s2dude
                            • Nov 2005
                            • 1631
                            As a sidenote what do you guys think to replacing the disk protector guards???
                            Mine are totally shot and Im thinking is it worht replacing them while Im there or is ther no great need for them and shall I just save the £18 + VAT per side iirc
                            • s2driveruk
                              • 12696
                              i'd say if you were going to uprate everything sooner or later then £45 would be better spent on new rs2 hardlines and the flexis than the guards, if keeping stock then i would get new ones
                              1992 3b S2 Coupe
                              • s2dude
                                • Nov 2005
                                • 1631
                                Thats a very good point mate....Cheers
                                Im strongly considering get a Big brake Kit very shortly so will this mean that the Disk Guards will not fit???
