Finally on!
  • stevieyid
    • Apr 2005
    • 2251
    Finally on!
    Finally fitted my Hi-Spec brakes newly painted with the s2 logos on. What do u lot think? Also a quick question what tyre pressures shall i run with the s4 alloys? Cheers
  • stevieyid
    • Apr 2005
    • 2251
    And another?
    • Jon441cc
      • Dec 2005
      • 2061
      I love the hi-spec calipers ... nice to see something different
      wheels look really nice tho
      • stevieyid
        • Apr 2005
        • 2251
        Needs lowering a bit i think maybe H+R on stock shocks.
        • Jon441cc
          • Dec 2005
          • 2061
          get yourself some H&R coilovers
          • stevieyid
            • Apr 2005
            • 2251
            would love to but money is the key. How much are they?
            • Jon441cc
              • Dec 2005
              • 2061
              £726.68
              • Chris5044
                • Feb 2005
                • 1663
                wow ... what is there a cheaper method... without sacrificing performance?
                • Corey
                  Banned
                  • Sep 2003
                  • 2793
                  performance isn't cheap
                  Corey
                  01636 822288
                    Shorter springs will normally be stiffer and will therefore need stiffer shocks (more damping) to control them.
                    Lowering alone is for looks, doesn't really help handling, traction, ground clearance or ride quality, you wouldn't want to drive the Rusper road on lowered H&Rs Stevie
                    Shocks now, thats a different story..
                    • dan_b
                      • Sep 2003
                      • 3670
                      What tyre sizes do you have there?
                      Calipers look nice, good one!
                      • Chris5044
                        • Feb 2005
                        • 1663
                        @ newsh... u sure u know what u are saying? cause a lower car = lower sense of gravity = prevents car roll and helps traction to a certain degree ....
                        I was also referring to possibly the h&R springs wit bilstein arrangement .. would it be cheaper than the ones above?... if about the same ... which is better?
                          Newsh is right Chris you need uprated shocks to go with lowered springs else the shocks go toast in no time as they get overworked.
                          • stevieyid
                            • Apr 2005
                            • 2251
                            Ill get saving, probably go for the koni and h+r setup as thats what i have on my UR and that works well.
                            @Dan,the tyres are 225/45/17. What tyre pressure should i run these at?
                            • Corey
                              Banned
                              • Sep 2003
                              • 2793
                              Yeah but when you fit lowered springs onto stock shocks you take the shocks past their optimum working range, so yes you may have lowered its CofG but your damping will not be matched to the spring rates.
                              That is why I only ever advise people to use Koni's and H&R's as these 2 products are designed and tested on the vehicles that they are designed for, rather than what some other manufacturers do and just take the stock items specification and change that by 25-30% to uprate their product and do no dynamic testing of their product.
                              Corey
                              01636 822288
