Well there are 360X34mm A8 discs! Think that they have the same offset/pcd etc.
Problems? First they are ****** heavy! Second not sure whether those GT3 calipers can accomodate such an increase in the disc radius. Obviously the widths ok.
Guess there is only one way to find out!
Have seeen them used on the 993tt 323X32mm disc but with a bell.
I was thinking that it'd be ok just to make a pair of spacers beind the pads - shape 'em like the pad and voilá - there you go! Or is that too acricultural??
according to a a post on here they where designed for 34mm, do you have a part number for them?
All I can tell you is they are fitted to the A8qL 01/03-12/06. The L being the long wheelbase version. They are only $180 in the States so they are not fancy two piece floating jobbies.
Hopefully one of the resident parts wizards can post the p/n and price.
i program a laser profiler all day, so i could shape them to within 0.09
Just what I was thinking... Had they been 2-piece you could have milled down the mounting face a couple of mm. But then they'd be dedicated to 30mm discs. I think a spacer would work though.
