which disc's for GT3's?
  • WabTheKing
    • May 2004
    • 2567
    may have got a pair of GT3's
    have read in another post that the 328x30 a8 disc isnt thick enough as they are designed for 34mm thick anyone got an alternative besides bells?
    cheers
    will
  • WabTheKing
    • May 2004
    • 2567
    having said this - 2mm a side can't make that much differance can it?
    cant see it making the earth stop spinning
    • zlobo
      • 967
      there is also 323x30 from s6+
      ABT C5 Lord Of The Rings
      2004 1/4 Mile ET 12.00 191Km/h @1,5Bar
      2009 1/4 Mile ET 11.92 213Km/h @ 1,5Bar 437WHp
      2010 1/4 Mile ET 11.45 110Km/h @ 1,5Bar 437Whp
      kostic.nu
      • WabTheKing
        • May 2004
        • 2567
        more thickness is what i need,
        what are rs2's? are they the same hub dia? could re drill em 112pcd
        • MidnightBlueS2
          • Jul 2005
          • 1653
          • Home: United States Current: Belgium
          RS2 discs are 32mm wide...
          Midnight Blue S2 - SOLD - 1993 S2 Avant
          • WabTheKing
            • May 2004
            • 2567
            mm just found a pic of them hub dia looks massive and there only 304 dia
            • twoqu
              • Sep 2003
              • 3103
              Hi!
              Well there are 360X34mm A8 discs! Think that they have the same offset/pcd etc.
              Problems? First they are ****** heavy! Second not sure whether those GT3 calipers can accomodate such an increase in the disc radius. Obviously the widths ok.
              Guess there is only one way to find out!
              Have seeen them used on the 993tt 323X32mm disc but with a bell.
              • WabTheKing
                • May 2004
                • 2567
                according to a a post on here they where designed for 34mm, do you have a part number for them?
                • Henka
                  • 585
                  • Home: Sweden
                  I was thinking that it'd be ok just to make a pair of spacers beind the pads - shape 'em like the pad and voilá - there you go! Or is that too acricultural??
                  • twoqu
                    • Sep 2003
                    • 3103
                    All I can tell you is they are fitted to the A8qL 01/03-12/06. The L being the long wheelbase version. They are only $180 in the States so they are not fancy two piece floating jobbies.
                    Hopefully one of the resident parts wizards can post the p/n and price.
                    • WabTheKing
                      • May 2004
                      • 2567
                      i program a laser profiler all day, so i could shape them to within 0.09
                      • Henka
                        • 585
                        • Home: Sweden
                        Just what I was thinking... Had they been 2-piece you could have milled down the mounting face a couple of mm. But then they'd be dedicated to 30mm discs. I think a spacer would work though.
                        • twoqu
                          • Sep 2003
                          • 3103
                          No point in making spacers for the pads. You might as well just keep an eye on the pads wear.
                          • WabTheKing
                            • May 2004
                            • 2567
                            are those 360x34 def not a floating disc? my man in shop had no listing for them or are they of the latest A8?
                            • AndyP
                              • 6049
                              Check out this site:-
                              They list the A8 6.0 W12 as having a 360x34mm front disc.
