As a follow on to my previous thread re my disc fitment issues it seems after much measuring and checking that the Caliper Carrier Lugs are in tact and fine and that the problem lies with my hub not being fitted properly.......
or not on far enough to allow proper brake disc location in realtion to the caliper carrier
I have not had this assembly apart before (Yet!!!) so can anyone enlighten me on the best way forward here please
Could the hub be "loose" and does the main 27mm nut actually tighten the hub on to the bearing housing?? Is it possible it is not seated properly due to a loose nut?
no visible play in the hub and bearing seems fine. Im yet to try and further tighten the big nut as I dont have a 200nm capable torque wrench
Suggestions welcomed p[lease guys
the gap from the rear face of the hub to the actual bearing housing is 1.8mm greater than ther "good" side. This is causing me all sorts of problems with fitting brakes and caliper etc as the disc is located nearly 2mm out of its correct position.
the hub is on square and the measurement is the same on all points of it.
