not sure if there big reds or small can anyone help please, the only numbers on them are 20.4585.00 can't seem to find any part numbers on them.
new brakes,but...
Hi!Originally posted by kingos2not sure if there big reds or small can anyone help please, the only numbers on them are 20.4585.00 can't seem to find any part numbers on them.
The Big Red casting numbers I have written down are 20.5249.00 and 20.5248.
Measure down the pad guide from top to bottom. Should be @ 72mm for the Big Red as it uses a deeper pad than the RS2/993 caliper.Comment
the piston dirt seals are bubbleing and one of the brake hoses at the back is bent anyone no were i can get new ones, also what paint do you use on referb, the biggest piston is 72mm top to bottom sorry guy's but im confused,
the caliper measurements are-
length=800mm
width=600mm
bracket length=190mm
if this helps.
anyone
That is the same number cast into the new standard RS2 calipers I have.Originally posted by kingos2not sure if there big reds or small can anyone help please, the only numbers on them are 20.4585.00 can't seem to find any part numbers on them.
Audi part numbers 8A0 615 106E / 105EKingdoms are run by Kings, Dictatorships are run by Dictators.
England must be a Country. :mischeif:Comment
ok finally got these fitted,parts used-
1-rs2 little reds (confirmed they are by audi)
2-rs2 brackets and bolt's
3-ferrodo pads
4-a8 314x30mm disc
5-golf gti braided hoses
6-7mm shimmes on caliper bolts to give space for the massive disc's
right then the calipers were very close to the wheels (i have 17in et 35) so i put 5mm spacer's and extented wheel bolts by 5mm on now i get wheel wobble at speed and sqeeky noise when on half or full lock left to right and sqeeeeling when braking at slow speeds, just woundered if any one new what might be causing this thank you. big thanks to the info from people for helping with this upgradeAttached FilesComment
Look very nice, where are the discs from and how much? Think i might be going 340mm route :mischeif:ChefComment
