new brakes,but...
  • kingos2
    • May 2005
    • 129
    • Home: England Current: Germany
    new brakes,but...
    not sure if there big reds or small can anyone help please, the only numbers on them are 20.4585.00 can't seem to find any part numbers on them.
  • kingos2
    • May 2005
    • 129
    pic 1
    • kingos2
      • May 2005
      • 129
      also woundering if anyone can tell me how to refurb them and service them cheers
      • kingos2
        • May 2005
        • 129
        pic 2
        • twoqu
          • Sep 2003
          • 3103
          Hi!
          The Big Red casting numbers I have written down are 20.5249.00 and 20.5248.
          Measure down the pad guide from top to bottom. Should be @ 72mm for the Big Red as it uses a deeper pad than the RS2/993 caliper.
          • porkkis
            • 1994
            Looks like the "small reds" = RS2 std calipers.
            Take the pad end plates out and remove any oxidation underneath and reinstall. Check the piston dirt seals. That's it.
            • kingos2
              • May 2005
              • 129
              the piston dirt seals are bubbleing and one of the brake hoses at the back is bent anyone no were i can get new ones, also what paint do you use on referb, the biggest piston is 72mm top to bottom sorry guy's but im confused,
              the caliper measurements are-
              length=800mm
              width=600mm
              bracket length=190mm
              if this helps. anyone
              • kingos2
                • May 2005
                • 129
                anyone
                • jade
                  • Jan 2005
                  • 1811
                  • Home: New Zealand Current: Spain
                  Hi thats sounds wrong
                  piston size on small is 30mm & 40mm on the big 36mm & 44mm bracket 130mm to centre
                  of holes
                  Jade
                  RS 2 580HP
                  • BRY
                    • 3755
                    That is the same number cast into the new standard RS2 calipers I have.
                    Audi part numbers 8A0 615 106E / 105E
                    • BRY
                      • 3755
                      Double checked and it may be 20.4565.00 and 20.4564.00 on the opposite hand.
                      • kingos2
                        • May 2005
                        • 129
                        ok finally got these fitted,parts used-
                        1-rs2 little reds (confirmed they are by audi)
                        2-rs2 brackets and bolt's
                        3-ferrodo pads
                        4-a8 314x30mm disc
                        5-golf gti braided hoses
                        6-7mm shimmes on caliper bolts to give space for the massive disc's
                        right then the calipers were very close to the wheels (i have 17in et 35) so i put 5mm spacer's and extented wheel bolts by 5mm on now i get wheel wobble at speed and sqeeky noise when on half or full lock left to right and sqeeeeling when braking at slow speeds, just woundered if any one new what might be causing this thank you. big thanks to the info from people for helping with this upgrade
                        • terrybullwon
                          • Mar 2006
                          • 8782
                          Look very nice, where are the discs from and how much? Think i might be going 340mm route :mischeif:
                          Chef
                          • kingos2
                            • May 2005
                            • 129
                            brakes were from www.needforspeed.co.uk about 220 quid with vat a p&p
                            • Corey
                              Banned
                              • Sep 2003
                              • 2793
                              and your pads are only sweeping 75% of the disc face.
                              Corey
                              01636 822288
