I'm planning a change back from my one piece goodridge hose to a 3 piece setup with a hardline around the strut.
PeterP suggested in the 996 post:
replacing the softline with a goodridge hose and the S2 hardline with the RS2 versions: (partnumbers 8A0 611 721 left and 8A0 611 722 right)
Does anyone know if the RS2 (avant body pipes) will fit a coupe?
And is there any advantage in doing this? Bigger tube bore?
Lastly, will they have a different (ie not M10 x 1.0) thread?
Cheers!
Cheers!
and will not fail you, I have used these for brake hoses and for a replacement hose from the PS pump to the brake bomb (the crimped join on the OEM hose was leaking) and this runs at Mahoosively high pressure, with no probs at all.
