i have that be-bep sound and red light on my screen which makes me sick.
did pedal test yep its gone.
i want to know why bomb blows? what can damage this stuff?
thnx
The bomb has a diaphragm in it with inert gas (nitrogen?) behind it under serious pressure, the system pumps in fluid to a preset pressure which is then used as the brake assistance, like a servo. Over time, as Lee says, this diaphragm can perish or rupture and the gas is lost. Its very important to use the correct fluid in the system for this reason, mixing the different kinds can lead to early failure.
Normally aspirated cars have a vacuum powered servo for the brakes, on a turbo car vacuum is not always present so we have a pump-up bomb instead.
It's called a bomb not, as you would think, because of the shape, but because of what will happen if you try to remove it without letting off the pressure. Even with a worn out one always pump the pedal 20-30 times to make sure all stored pressure is gone.
I'd get the bomb changed at some stage rather than leave it.....that's how mine was behaving nand whilst it does work it is on its way out.....I spoke at length to AmD about it before getingit changed. One of their customer had a bomb behaving like this an had an engine problem whilst driving....no brakes to speak of once th engine died....on fun.
Personnally having had a Mk 2 Golf Gti throw a rod thro the block whilst on the right hand lane of the M25 at 75mph brakes in that type of emergency are a real help......so I got mine changed sooner rather than later.
The thing is as newsh said except the name. It really comes from the shape. It's totally safe component to work with.
Pressure is around 70-75bar when new, 0bar when totally dead.
New bomb costs around 400e new (doh!).
There are aftermarket replacements made by Febi-Bilstein for half the price.
When renewing the bomb change the hydraulic oil at the same time. Most of it comes out when you remove few of the hoses. Rest when steering is turned lock to lock few times to empty the power steering. Clean the mesh "filter" in the container at the same time. Use only good quality hose clamps securing the return hoses as they usually do leak a bit.
Use only original hydraulic oil or similar. Febi has a cheaper synthetic option that I use without problems. Half the price again.
A guy here in the U.S. recharges them in his basement for $60. I have used two so far (on different cars), they work great!
The nice thing is that the valve is there to recharge it should it go low again.
Dave K.
USA
1991 e//S2 (home built S2 - the only way to get one in USA!)
2001 S4
Yep - good advice. Check www.20v.org for more tips. This part is the same as our lame 7A powered cars...
Dave K.
USA
2001 S4
Originally posted by porkkis The thing is as newsh said except the name. It really comes from the shape. It's totally safe component to work with.
