Cheers. The peddle is normal as in it presses slightly, then goes hard about halfway down. If you are sat at a standstill and have your foot on the brake it judders under foot. Confused
Mark
Race Clio RS197
S2 Coupe ABY (Green) - RIP
S2 Coupe ABY (Blue) - Sold
Mines started doing this recentley, feels like the ABS is kicking in even when you are sat at the traffic lights. Only does it every so often though, nothing consistant.
I had something not dissimilar with the cq20v. Turns out it was the lead worn through on one of the front the ABS sensors - it had been looped the wrong way when the suspension was upgraded and was able to rub against the inner wheel. Fortunately it was easy to fix!
cheers
Paul
Trick Pearl White 1992 3B S2 Coupe. Porsche 996 monoblock stopping power! HID Seeing power! Mmmmm Miltek!!!
Trick Indigo Pearl B5 S4 Recaros, Bose , Mmmm Miltek!!!
