ok. To cut a long story short I allowed my road tax to lapse and realised at the same time the MOT expired last month.
I've got an ABS fault and two new sensors to fit!! (theyre missing being the problem most likely!) I know they are an easy job but I have to remove a hub first to clean it up as the previous idiot owner didn't seal the ABS sensor hole....just left it open
I know the car will fail for the ABS light being on so I want a quick fix to help it through the test tomorrow and then I will fix it fully on its return (MOTd and taxed hopefully)
if it fails I will have to declare it SORN until she's sorted
NOt good.
So...is there a fuse somewhere that I can pull that will de activate the damn light?? or even the main ABS ECU harness?
or is removing the bulb from the dash the only way forward??!! (I know...a real botch
THANKS
NOt good.So...is there a fuse somewhere that I can pull that will de activate the damn light?? or even the main ABS ECU harness?
)THANKS
Gonna change them tonight and book it in last thing Friday all being well!! Though I will hopefully have fixed the ABS by then unless it is the ABS ECU in which case the bulb is a comin out
