Different Brake Bomb problem
  • s2avant
    • 2426
    As always my avant can't seem to just have a normal problem it has to be something different.
    I'm doing my Porsche brake upgrade in the next couple of weeks (the goodridge hoses finally landed today ) so I thought it best to do the pump test etc so I can change anything else while it's apart.
    It passes the pump test with ease (over 50 pumps). The problem is when the engine is running and you pump the pedal 4-5 times the warning light (!) comes on and it starts beeping.
    It occasional comes on when you start it from cold too. Is there a problem or am I chasing non-existent gremlins? The only thing I can think of that might be at fault is the hydraulic pump as the power steering feels very stiff when the car is fully loaded.
    Ben
  • Sidspud
    • 1223
    • Home: Scotland Current: United Nations
    I get the same problem when I pump the pedal with the engine on. I havn't tried it with the engine off though.
    I think I have a problem as every time I come to a halt after braking lightly I get wierd pinging noises - kind of like a big spring twanging.
    I'm thinking of taking it to my local dealer to get the brakes sorted once and for all. I've get the ABS warning light lighting up whenever I go over 30mph.
    It does stop though, but I've not got the confidence in it that I should have with Porsche brakes on the front.
    ex '93 Avant owner
    • *ZenithalRavage*
      • 216
      Re: Different Brake Bomb problem
      Ben
      Hey, I'm interested in this too! I just read about this fault recently. I never thought something of it and I've had it ever since I bought this baby (now 9 months), (!) on display and three beeps on every start ever. I guess I'll do the bomb test tomorrow and I don't see much chance of passing it having this error for so long. :eek2:
      *ZR* S2 R.I.P.
      Visit *ZR*'s Hideout!
      • Mikes2
        • 1704
        Sounds like a servo problem. You can confirm if it's leaking by disonnecting the return hose. More than a small number of drips and it's new servo time
        Mike
        http://www.s2-audi.co.uk
        • Doug_RS2
          • 3847
          Interesting - Will this servo problem cause the pedal to go soft/ further to the floor after a few quick hard presses while the engine is running?
          • Vagsport
            • 533
            If you are getting a 'pinging' noise on breaking, you have an ABS fault. I'll bet my biturbo on that!
            Siena
            • Mikes2
              • 1704
              Doug,
              No - that's a brake master cylinder problem or air in the fluid.
              Mike
              • Sidspud
                • 1223
                Cheers Siena. Don't you just love this forum. This fault has been bugging me for months, but now that I know I've really only got one brake problem rather than 2, it all seems a bit less daunting. OK so I still have an ABS problem to put right, but at least I know where to start looking.
                ex '93 Avant owner
