Situation:
I was converting the B4 Quattro 4lug hubs to S2 hubs. But the front wheel bearing of B4 is 75mm and S2 wheel bearing is 82mm. This means that my current drive shaft wont fit. Rear is both on B4 and S2 75mm so no problem there.
What the hell is the solution? Is it possible, that B4 2,8 has 82mm bearing in the front and so by getting the driveshaft from 2.8 B4 I can bolt it right up to my s2 housing that I also have?!
I need some solutions fast guys. AAN engine is in and rs2 brakes waiting, so is the track.
And is there a diff between S2 and 2.6/2.8 shafts... Anyway I'm getting tomorrow 2.6 shafts and then i'm smarter again. Hopefully.
I just dont have that time.
