Autocheck annoyance!! Fault finding?.....
  • s2dude
    • Nov 2005
    • 1631
    ok guys...
    So after working through a seemingly never ending list of problems and warning lights the beast just flew through its MOT
    I had quite an issue with corroded terminals and mild oxidisation to some of the bulb holders on the rear light bulb holder units...
    So I revamped them , All new rear bulbs, sorted a variety of electrical niggles out and all lights now working fine...
    Autocheck does the brake symbol on startup....press pedal..it goes and is replaced with the OK symbol.
    But turn the lights on and I get the "bulb failure" warning lamp (handbook says "dipped headlights or rear lights" even though both Headlights visually work fine and both rear lights do too??!
    In fact I (with the help of a friend) tested just about every combination of lights on the car...including foglights etc.
    All working fine. Checked fuses and as expected all was ok.
    Does anyone have an idea if a "dodgy" headlight bulb could be causing this...as in it works but trips autocheck on??
    Also, how can I check the autocheck system is not at fault in terms of how it monitors the front and rear lights?
    All ideas and suggestions welcomed
    THANKS
  • s2dude
    • Nov 2005
    • 1631
    any ideas guys please??
    • Fat Audi 80
      • 10547
      Are you running HID's??
      The Perfectionist
      • s2dude
        • Nov 2005
        • 1631
        Hi mate..
        No. Not that I know of!!!?
        • Fat Audi 80
          • 10547
          The retro fitted HID lights can cause autocheck problems...
          But not in your case if you don't have them fitted.
          The Perfectionist
          • s2dude
            • Nov 2005
            • 1631
            Cheers for that info mate..
            Im going to whip the headlight out and see what bulbs are in there ..pretty sure they are standard but if the wrong bulb has been fitted at some point ?? who knows?
            • Fat Audi 80
              • 10547
              If you have HID's you will have Ballast boxes under the bonnet near the lights! You would know if you had HID's, they are the dogs privates...
              Cheers,
              Steve
              The Perfectionist
