330mmx30mm replacement discs
  • ericd
    • Nov 2003
    • 1240
    Originally posted by Bibby
    I ended up selling my Alcons and running with the Porsche 996 calipers. The Alcons were just too much hassle for a daily driver.
    Great brakes, but a pain in the butt (and wallet) when it comes to maintenance.
    Alcon don't make it easy to get info and buy their stuff (unless you're running a rally team !), but they've been on and lasted for just over 11 years now and the grooves are beginning to wear off , so hoefully they'l last at least another 10
    • ericd
      • Nov 2003
      • 1240
      Does 13/14Nm for the bell/hat bolts sound about right
        Yeah sounds about right, i'll see if I can dig out my AP manual which should be pretty similar
        • ericd
          • Nov 2003
          • 1240
          changed the discs today, If anybody wants the old ones to re-machine/modify (originally (13")330mm/30 mm thick on a 12/203.2mm (8") pcd, then let me know , you'd have to pay for postage or I'd bring them to the next meeting I attend, would have posted pics , but can't seem to get them into the post anymore
          quick thanks to Bry & Corey for their suggestions on alternative option/s
          • ericd
            • Nov 2003
            • 1240
            Bump, if anybody wants the old discs for whatever , let me know otherwise they're heading for the bin
            [IMG]12795[/IMG]
            • sfowler80
              • Oct 2006
              • 16
              I am having similar problems finding replacement discs for my ap calipers (330/28mm) dont suppose anyone has any for sale or could point me in the direction of a good retailer. Have been quoted £465 for the discs alone so far was hoping to do better!!
              Any help would be appreciated.
                try giving BG Developments in Bromsgrove a call, they were very helpful when I did my conversion
                • ericd
                  • Nov 2003
                  • 1240
                  Is it a 2 piece disc ?, drilled, grovved, vented ? pcd: ?, there were definitely a few options available on a 330 by 28 or 32mm, DBA and a few others have them, I'm sure Corey or Bry can help with some suggestions/alternatives
                  • sfowler80
                    • Oct 2006
                    • 16
                    Yes they are two piece with 12 bolts holding them to the bells/top hats, vented and grooved. I think the pcd is 35 but i havent measured it, is that the depth of bell/top hat?
                    • ericd
                      • Nov 2003
                      • 1240
                      The pcd is the diameter of the mounting holes on the inside of the disc, typically on a 330mm disc it should be (8" = 203.2mm), you should double check it though. Also worth checking US sellers who do a lot of Wilwood or performance friction rotors, I'm guessing Brembo will also do one at your size.
                      Hth
                      I think the "35" you're referring to is the wheel offset
                      • sfowler80
                        • Oct 2006
                        • 16
                        Thanks for the info, this site really is a big help for novices like me!!
