Brakes gone.
  • Brakes gone.
    Hello,
    I have recently problem with brakes.
    After boost brakes are hard been always but now i have other problem also. Now even when i brake sometimes pedal is hard or if its not and i repress pedal it goes hard and need to press brakes with to legs to stop
    I have vacuum brake system. We have checked that little valve but this looks ok. So it looks i have to change brake booster?
    If i have to change that then is there better options than B4 booster? Or how can i be sure its brake booster problem?
    I have in my warehouse booster as in pictures. But i cant find that this coded booster will go to my S2.
    Many thanks for help!
    This gallery has 2 photos.
    Have some one installed that brake servo to his car? Its two chamber on and it looks like its S4 one.
      I had similar symptoms on mine, the vacuum booster has a leak. I fitted a new one and it's been fine ever since.
      Not good coming off boost to find you have no brakes!
        Yes,exactly! But i dont know, will i fit original Audi 80 one like now i have or but two chamber booster like S4 B5 one that i have. It must be better but does it go bolt on??
          Have you checked the check valve?
            By mouth,yes. Looks ok.
              There is also an o-ring seal between master cylinder and booster / servo which can leak.
                How i can test that?
                  Run the engine then switch off and see if you can hear a hiss sound, or use leak detection spray, or vacuum tester
                    Cheked again valve and its Ok. I made test like error404 said and found one leak. But its So little hose and i dont think its A problem? What hose is this?
                    i Will to testdrive when snow is gone because i have Right now summer tires on it
                      This gallery has 1 photos.
                        Looks like one of the boost pipes, I would fix regardless. You have some play so may be able to cut end and refit
                          This gallery has 3 photos.
                            I made bigger picture. The blue hose is below valve. Does this hose effects fuel pressure?
                            And hose already fixed.
                            Can someone knows what did hose effects?
                            • #15
                              Can i make sure somehow its booster fault for sure?
