Right, 911 callipers are on the front of the S2 now, they feel good even though I havn't tried them yet. One thing though, after a few 60-40, 40-20 on and off braking, when I pull back onto my road going 10mph a slight ringing noise can be heard. This only seems to be when I manouver the car right to left and then in straight line after this. It can be kind of felt in the transmission tunnel too, but I'm guessing that a metal on metal noise from the brakes would vibrate along much of the car? Strangely though, if I drive the car 1minute afterwards at the same manouvering speeds, the sound has gone away! Which makes me think that the expanded disk has contracted again...
But...
Inspection of the disk shows no score marks except those left by the pads and feeling across the surface, they feel perfect (like 30mile-old disks should be!).
The metal protusions on the inside of the calliper are still very close, even though I ground them down a mm or two, and I still think that their maybe touching the disk when it gets hot !!!! But you'd think there would be visible or feelable (is that a word?!) score marks on the disk!
So annoying, because appart from that the brakes feel great and look even better!
Phil
But...
Phil
