I've recently had my brake servo overhauled, and I bought a new master cylinder at the same time. After I fitted the new parts I bled the brakes thorougly, on both the inner and outer bleed nipples on all calipers. The brakes work like a charm, and I can easily lock up my studded winter tyres. It's a bit difficult to really test this in the Norwegian winter. The only "issue" that I have is that the brake pedal returns slowly. The brakes release as soon I take my foot off the pedal, but the pedal itself returns slowly. I'll guess that it takes around a second for the pedal to return fully.
If I pump the pedal a bit a couple of times before i hit the anchors, the problem seems to go away for a little while. I've also replaced the bomb a couple months ago.
