rs2 rear calipers on an s2
  • QuattroFever
    • May 2006
    • 1360
    can anyone give me a link to this huge thread thats on here about fitting rs2 rear calipers.
    I've been trawling for ages I'm nearly convinced its been taken off!!
    It was named something like RS2 rear brakes on a coupe
    Volcano ABY coupe
    Ant
  • BRY
    • 3755
    linky
    • blown_vr6
      • Apr 2005
      • 406
      Bit of an overkill to me - loads of work including using RS2 hubs/handbrake set up etc...
      Youd be better off buying some 4 pots with a built in handbrake caliper ala Wilwood or similar.
      'If you ain't broke it you ain't trying hard enough'
      Oh sh*t i broke it
      94 S2 Homefried Decatted Slipperwagon,QRS Top Mounts,Ally Subframe bushes,Poly ARB & Wishbone bushes,RS2 ARB's,Koni & H&R's,Cupra Brembo's and 312mm discs
      • QuattroFever
        • May 2006
        • 1360
        Cheers BRY
        Volcano ABY coupe
        Ant
        • QuattroFever
          • May 2006
          • 1360
          def. would be easier and cheaper but I've already got porsche ones on the front and wanted to keep them the same. bought the rear calipers already too.
          Volcano ABY coupe
          Ant
