BMW E38 4 pot Brembo brakes.
  • BMW E38 4 pot Brembo brakes.
    Hi,
    Have someone using those brake calibers? What disc will go with those calibers in front to S2?
    It would be better to buy Boxster s front calipers or you will need the right discs with right pad swept area and hat height on discs and custom brackets for your s2 btdt.
      Originally posted by ristokru View Post
      Hi,
      If im correct you have 314mm rotors under your S2 replica.
      1990 2.2 20VT Audi Coupe Quattro
      *Hx35/k26, MaxxECU, Wagner EM/IC *RS2 Recaro *4pot-Brembo *3" turboback *Treser *Koni/H&R
      1990 Audi 200 20v Avant 2.2 20VT *7 Seater *Full electric gizmos
        Yes I have but it’s not a replica lol
          I have already installed Brembo brakes in my car but i need to rebuild calibers. But to me it looks that those brakes with disk dont use all the surface. Inner side of disk i have 2cm unused surface.
            I see so you have these e38 4 pots with brackets. What discs have you used?
              314mm disks.
                Risto has a replica S2 sedaan, not talking about your coupe S2.
                Risto, changing rotors doesnt help you with the problem you have. You have to use other pads than BMW uses because the hat size is different on BMW rotors.
                  Armored Mercedes-Benz pads.
                    Kiku. Let go my replica word
                    Thats why i made this topic. Maybe i have wrong pads for my setup. So 314mm disk is ok? So what pads is correct for this setup? Anyone knows?
                      I've a b3 with Brembos.
                      But 4 stud. It uses focus rs discs.
                        4 studs? You mean with 4 pistons? What size of discs and what pads you use?
                        Can anyone say what pad goes with 314mm disc?
                          Like Shuriken said, armored benz 220 pads.
                            is this on you UR? all under 15 inch wheel?
                            sigpic_________
                            Rob
                            • #15
                              No. On my b3 90q. I think they're 17". Too big for anything smaller.
