RS4 B5 front brakes?
  • CliveH
    • Jun 2005
    • 1319
    Hi guys,
    I've just acquired an ABY S2 Coupe.
    Just wondering if anyone knows if the RS4 B5 front calipers can be used on the S2?
    The RS4 stock discs are 360x32mm.
    Thanks in advance,
    Past: S2 ABY coupe RS2 spec with lots of mods, S4 B5 saloon, RS6 C5 saloon, S8 D2 FL, RS4 B7 saloon, S4 B6 avant
    Present: S4 B8 avant, MRC Stage 2
  • Corey
    Banned
    • Sep 2003
    • 2793
    Nope because the bolt spacings are wrong on the caliper carriers, the only good brake upgrade on the S2 is the tried and trusted method of Porsche caliper's
    Corey
    01636 822288
    • CliveH
      • Jun 2005
      • 1319
      Thanks for the prompt response Corey
      It was a bit of a long shot, I know, but thought it was worth asking as I have a pair of said calipers in the garage...looks like it's the Porsche route it is then...
      Which is the easiest/cheapest option? 993/996/Cayenne/Boxster?
      • CliveH
        • Jun 2005
        • 1319
        Just another thought - is it not possible to use a customised caliper mounting bracket to accommodate?
          Use RS6 calipers http://www.s2forum.com/forum/showthread.php?t=15713
          Patented by S2avant aka Parts Daddy aka P.Diddy
          • Corey
            Banned
            • Sep 2003
            • 2793
            I would suggest selling the RS4 caliper's to an S4 owner with the suitable bolt spacing.
            The most cost effective (we don't do cheap ) route is the 996 monoblock route, looking at your sig I assume your S2 has the stock 16" Avus wheel, which would dictate you to go the 314mm diameter disc route, the better option is the 323mm diameter but this would mean swapping to 17" wheels, either disc is a good upgrade but obviously the bigger diameter disc is better and I am just showing you your options if you were considering larger wheels at some point.
            Corey
            01636 822288
            • Corey
              Banned
              • Sep 2003
              • 2793
              Hardly patented but yes if you want the biggest but hardly cost effective, lol
              Corey
              01636 822288
              • BRY
                • 3755
                BSA Racing hold the patent on the bracket design.
                Audi designed the rest.
                • Corey
                  Banned
                  • Sep 2003
                  • 2793
                  Only half of the bracket
                  What do you call a bracket that holds a bracket anyway
                  Corey
                  01636 822288
                  • s2dude
                    • Nov 2005
                    • 1631
                    Perfectly possible.
                    Just find yourself a decent engineering shop. Take the whole caboodle to them (hub carrier,caliper, brake disk etc....and get them to machine a pair up for you to suit
                    • Jon441cc
                      • Dec 2005
                      • 2061
                      Use the B5 discs with these bad boys
                      http://cgi.ebay.co.uk/PORSCHE-GT3-GT...ayphotohosting
                      • BRY
                        • 3755
                        Development for a customer on a tight deadline.
                        • Corey
                          Banned
                          • Sep 2003
                          • 2793
                          I'm in love
                          Corey
                          01636 822288
                          • Corey
                            Banned
                            • Sep 2003
                            • 2793
                            hahahaha
                            Corey
                            01636 822288
                            • s2avant
                              • 2426
                              Is there anyone eslse who fancies slagging off my brakes? I'll start a new thread for it if you like...
                              My apologies for going for something a bit different. My point was to show what could be done with OE parts. I didn't realise I was going to be frowned upon because I don't use second hand porsche bits to slow my car down
                              I best keep my rear brake setup a secret as that wasn't sourced from the set of scrap heap challenge either.
                              Ben
