problem after porsche 996 conversion
Sounds like you have the wrong discs fitted. Regardless of the diameter or width, clearly the disc should be centered on the hub. Either that or your hubs have been modified.
What is the history on the car? What brakes were fitted before? Who supplied the discs? Etc.
More information and better description of the issue is required - pictures tell a 1000 words
Imola B6 S4 AvantComment
I agree with Error...
It sounds like your disc center-bore is loose (radially) on the hub and is perhaps only being centered by the wheel studs, a job they cannot properly do. The disc needs that hub shoulder on which it fits onto, in good contact (should be a nice snug fit) with the disc's center-bore surface to leverage against when the brakes are applied, or else the disc will get pulled to the limit of it's stud clearance holes (depending on wheel nut tightening torque and technique) and hit the underside of the caliper bridge like you describe.
I understand that there are different versions of the required disc for this conversion. If none of the parts have been altered (particularly the hubs), is it possible that these particular discs are just made with a centre-bore too large?
When you back up and apply the brake, you are causing the disc to be pulled back to where it was, sort of. Likely it overshoots the original position. New position, slightly different noise or briefly (because the disc is still not really fixed radially) no noise.Last edited by Lago Blue; 19 August 2018, 15:30.Comment
Tango,
I cannot confirm the P/N, best get on to someone who has done this mod successfully (there must be a few!) and compare notes. Suggestion, pictures seem to draw folks in. for instance, can you take the wheel off and show how the disc moves, where it rubs, etc.
Cheers.Comment
I buy off-the-shelf Brembo Mk1 A8 discs off eBay for between 30 and 50 quid each.
(The lowest I’ve paid for one disc was I think £29)Comment
For information purposes. These are pictures of the 996 caliper, 323X30 rotor with RS2 caliper carriers. They fit under 16 inch Avus wheels. I put a light behind the wheels, so you could see the clearance.
Greg W.
This gallery has 2 photos.They can have my car when they pry my cold dead fingers from the steering wheel.Comment
