Hello!, the problem it´s my mechanic (and two others previously), do not hit the key to make the handbrake work. The left side it brakes enough (checked in the MOT) but nothing in the right side. In fact to pass it I had to put on top of the lever and pull like a possessed with both hands. The mechanic adjust it as much as possible, and for a couple of uses it brakes enough to hold the car on a steep ramp, but then no brake enough. Put new shoes, also changed a spring, and now the mechanic told me that the cable on that side was rusted inside its case and that it was not working. I bought the original cable and installed it and it still does not stop. Does anyone have an idea what the problem may be? Thanks for possible answers.
PD- Sorry for my english
