RS2, impossible to adjust handbrake
  • epimalone
    • Mar 2016
    • 20
    • Country: Spain
    Originally posted by rxl
    kinda stange problem. if your one wheel pulls more than other it makes sence to make it less biting and then adjust the cable on car.
    well if its the cables then you can order new from audi tradition.
    Order in audi tradition it´s more difficult than adjust my rs2 handbrake
    • mac2226
      • Jun 2008
      • 1289
      I would of thought there adjustable inside the drum there’s usually a tooth gear that you push clockwise or anti-clockwise to tighten or loosen the brake pad shoes. There seen through one of wheel bolt holes you use a thin long screwdriver to turn the gear but I could be wrong that’s how I did mine on a bmw
      • rxl
        • 1913
        not realy a problem if you live in germany. if you want i can order them and after i get them reship them to you
        • John.
          • 2615
          Yup.
          • A80Avant
            • Sep 2005
            • 10873
            • Country: Greece
            #20
            Yes there is the drum mechanism but again after a couple of gas tank fill ups ie 1000kms or so it comes loose again
            • epimalone
              • Mar 2016
              • 20
              • Country: Spain
              #21
              thanks for your offer, but i will wait to buy the other new handbrake cable
