Audi s2 avant -93 ,, brake upgrade
This is a sticky topic.
  • S2_avant 19930325
    • Mar 2019
    • 648
    Hi .. i know that there is tons of info on the rear brakes ,, if you want to upgrade.
    But when i search it seems that there is not anybody with 100% pure facts what works.
    I seems there is a lot of .. maybee,, it should fit,,,and so on.
    Mine is manufactured 93-03-25.
    Can somebody give me a tip for rear brake upgrade , i knor there are kits to buy nut i want from cars that i can buy used.
    I have access to a tool ahop for modifing the parts.
    Im willing to modify if i can get info to what measurments to use.
    Thanks guys for a great site.
    • Dec 2017
    • 6006
    Here is what I did and I confirm it's easy and works.
    Second hand S4 B6 rear calipers and carriers. Refurbished with kit from Autodoc.
    New vented discs for S4 B6 from Auto doc (you just need to bend the dust shield slightly to fit).
    Remove the handbrake levers from your S2 calipers and mount on the S4 calipers.
    Custom stainless hose from HEL from calipers to hardline.
    Pics in my rebuild thread.
    • S2_avant 19930325
      • Mar 2019
      • 648
      Great . a question what year are your avant ? Is it not any difference from early 93 and late 93 and newer ?
      What year was the S4 B6 model ? Is it a single piston caliper ? Size of the disc ?
      • S2_avant 19930325
        • Mar 2019
        • 648
        Do you have any part numbers written down ?
          • Dec 2017
          • 6006
          These are from my note book. Check before you use them to buy anything!
          Left caliper 8E0615423C
          Right caliper 8E0615424C
          Carriers x 2 8E0615425B
          Bolts x4 N01024124
          Pads 4B3698451 Ridex 402B0643
          Discs 8E0615601K (300x22 vented) Ridex 82B0924
          I can't find the caliper overhaul kit part numbers at the mo.
          When I did mine there seemed to be lots of B6 S4's being broken for parts (timing chain stretch issue) and I got all the parts I needed for £150. I took the registration number of the donor car and used it to order the disc's, pads and overhaul kits. I spoke to Hel directly and they made the pipe up for me to my spec. The only major issue I had was getting the handbrake cable to fit on the calipers. I did consider changing the cables but in the end swapped the lever and It works ok.
          My Avant is a 94. The calipers are single piston but big and more that enough for the job.
          • S2_avant 19930325
            • Mar 2019
            • 648
            8E0615425B .. is there any carriers from any other model that fits ? Not so easy to find the carriers and new one are expensive.
            Best regards
              • Dec 2017
              • 6006
              They are out there, you just have to know where to look.
              https://www.ebay.co.uk/itm/AUDI-S4-B...4AAOSwR6RclLy~
