S2 front brake disc
  • mac2226
    • Jun 2008
    • 1289
    S2 front brake disc
    can some body measure there pad swept area on the front oem discs and hat height please as I want some two piece discs making but haven’t got the discs in front of me.
  • mac2226
    • Jun 2008
    • 1289
    This is info I have so far 276mm diameter and 25mm wide the hat height 56.2mm and hub centering diameter hub 68mm hole. Just need the pad swept area on the disc outer edge to inner edge please.
    • twoqu
      • Sep 2003
      • 3103
      It might vary between disc manufacturers but I have measured 57mm on the front face and 58.2 on the rear face of a Tarox replacement 276mm disc. You might get more accurate dims of a technical drawing. Can't seem to find the Brembo one online. Might have it saved somewhere.
      Not sure what you are trying to achieve but usually a bell eats into the annulus!
      • twoqu
        • Sep 2003
        • 3103
        Like this:
