hi all iv come across a problem on the rear of the s2.
so under heavy braking the rear of the coupe locks up. It’s a absolute night mare on the track and not very nice in the wet.
i started with the standard rears and it was bad on them. Went to vented 300mm rears and it’s just has bad.
iv tried it with the abs on and the abs off. With the abs on it just hampers the rest of the braking.
If I put weight in the rear it makes it a bit better. But not a hide difference.
im running coilovers but was just has bad when it was on it original suspension. Any help would be nice
