The car starts and the ABS light stays on. If you slowly press the diff lock switch, the yellow triangle light comes on and the little green light. If you then slowly again depress the switch, the yellow triangle and green LED go out and so does the ABD light on the dash. But then after a few seconds or minutes with the car stationary, the light comes back on.
The reason why I saw slowly depressing the switch is because if you do it normally, nothing happens. On my RR it is instantly on and off etc.
I have an RR so have been able to swap out some parts. Here is what I have done so far:
1. Changed both relays in ABS pump.
2. Changed relay 76 under the dash and checked the 10A fuse.
3. Checked the one way valve under the rear seat.
4. Observed the diff lock actuator opening and closing when switched.
5. Changed ABS ECU.
6. Changes Diff Lock Actuator box in the boot.
Brake warning light stays on for about 10 seconds when the car is started which suggest a new brake bomb is required, but don't think this has anything to do with ABS.
Any ideas???
5. Changed ABS ECU.
Any ideas???
