ABS Noise - 3B Engine
  • ABS Noise - 3B Engine
    Another ABS fault. This time when driving there is a hissing/whooshing noise coming from the ABS pump area. When braking, the car squirms and you can feel the ABS through the brake pedal. Sometimes when you come to a stop you hear a 'boing' type noise.
    Previously the ABS light came on after 25mph or thereabouts. I've cleaned all the sensors and the teeth and the abs light has gone away. Car drives fine without the strange noise and brakes normal when ABS is switched off.
    Steve
    1990 RR 20V
    1982 SWB UR - RS2 Engine
    The 'boing' noise you're hearing is the hydrocoptic marzlevanes aligning themsleves with the lunar waneshaft to prevent side fumbling, all perfectly normal
      mmmm..... Need to get me some "side fumbling"....
        I've had a reply on this off another site and they have suggested that the air gap may not be correct. I thought that if it wasn't, then the sensor would not read and the ABS light would be on?
        Steve
        1990 RR 20V
          Gap was wrong on mine and the abs light came on. No strange noises or pedal feeling.
          Sounds to me like it might be the regulator or the abs pump itself.
          Nothelle S2 Avant in restoration
            Mine used to make a strange farting noise until I deleted the bomb so it must of been that
              A faulty, dirty or badly adjusted sensor can definitely make the abs pump cut in as you come to a stop. Classic symptom.
                I backed all of the sensors off today and the noise stopped. Just need to find the sweet spot now.
                Steve
                1990 RR 20V
                  So what is the sweet spot? I've made lots of adjustments and at certain speeds when braking, the ABS kicks in.
                  Steve
                  1990 RR 20V
