Rear brake disc options - new twist!
    #31
    Greg - the pads sit beautifully in place with the disc at 280mm... as you'd expect as that carrier and pad combo is for a 280mm disc on the A8/S8. I'll be fitting at the weekend (rain or shine) so will have some photos then.
    Last night I shortened some 50mm carrier bolts down to the 35mm needed on this install. I have fresh hydraulic lines and new rigid ones if I discover any ropey looking ones... So hopefully I am ready !
    Alternatively, the sun is shining and I just might sneak off work early to do this - yeah fat chance
    Cheers,
    Paul
      #32
      They fit - it is proven fact - Link to other thread with photos and more info.
      Paul
      • 90quattrocoupe
        • Nov 2003
        • 771
        Paul
        Nice work, Paul. Good to know there is another option for the rear rotor. Now if my A3s ever where out I will have less maching to do on the next set.
        I think once you get the 996s on the front, you will find you have a well balanced brake system.
        Thank you,
        Greg W.
